Search
Display results as :
Rechercher Advanced Search
Latest topics
» CARBON BONNETS AND AERO PARTS FROM CARBON TEKNICS
Mon Sep 24, 2012 4:17 am by samurex31
» WTS - Ultra Gauge EM ver 1.2 (New)
Sun Sep 16, 2012 6:13 pm by Raiijin
» RainAway Nano-tech Glass Coating Treatment
Fri Dec 09, 2011 12:22 am by GT35R
» Honto Racing - A chance to win an IPAD2 when you purchase LUKAS, FINEVu or MIR Blackbox!
Wed Nov 30, 2011 3:35 pm by hontoracing
» Online dating for business women. Dating mabie.
Thu Aug 04, 2011 8:26 pm by Guest
» Dating nancy. Ovation dating guitar.
Thu Aug 04, 2011 12:09 pm by Guest
» Newbie in the forum
Wed Aug 03, 2011 8:23 pm by Guest
» Auto Tran's Problems?
Fri Jun 24, 2011 1:07 pm by win
» Name for Sg Bravo Forum
Fri Jun 24, 2011 12:55 pm by chinalim
Social bookmarking
Bookmark and share the address of Singapore Bravo Forum on your social bookmarking website
Navigation
 Portal
 Index
 Memberlist
 Profile
 FAQ
 Search
Affiliates
free forum
POH HENG TYRESNEW THREAD
Page 4 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Go down
Re: POH HENG TYRESNEW THREAD
Post  jtan38 on Mon Apr 26, 2010 8:11 am
2nd hand rims for sale
work emotion replica 17 inches bronze with tyres
10 holes
work emotion replica 17 inches hypertitianium with tyres
8 holes
jtan38
Number of posts : 148
Registration date : 2008-03-25
View user profile
Back to top Go down
Post  jtan38 on Tue Apr 27, 2010 8:06 am
UTQG Ratings for Passenger Car Tyres
Many drivers may have noticed markings on the sidewalls of their tyres which list the following parameters, accompanied by ratings: Treadwear, Traction & Temperature. These are UTQG Ratings. UTQG is an acronym for Uniform Tyre Quality Grading System. All passenger tyres sold in the U.S.A. (this includes RV tyres) must have these ratings marked on the sidewall, excepting tyres with a rim diameters of 12" or less, deep tread snow tyres, & temporary spare tyres.
Only passenger car tyres sold in the U.S.A. market are required to have UTQG markings. For this reason, not all passenger car tyres sold in Australia have markings which show UTQG Ratings.
UTQG Ratings indicate relative performance for passenger tyres for the parameters of treadwear, traction & temperature. The following information explains how a tyre achieves each of these ratings.
Treadwear - This is a comparative rating based on the wear rate of the tyre tested under controlled conditions on a specified government test course. The defined "standard tyre" has a rating of 100. Gradings are in multiples of 20. The treadwear rate of all test tyres is compared to that of the "standard" tyre.
Test Procedure - A group of not more than four vehicles fitted with the test tyres travel the specified test course in convoy. Tread depths are measured each 800 miles. The tyres are run for a total of 7,200 miles. The specified test course covers 400 miles of public roads. The tread depth measurements for each vehicle are averaged to give a projected wear-out life. A treadwear rating of 200 indicates the tread wear rate of the test tyre was half that of the standard tyre.
Application of Test Results - The results for treadwear using the test conditions described above will directly reflect these test conditions. The actual conditions in which tyres are used will nearly always vary greatly from those used in the UTQG test, therefore so will treadwear rates. Factors such as the road surface type, tyre inflation pressure, vehicle wheel alignment, driving habits, & road surface temperatures will all affect treadwear rates in actual using conditions.
Traction - This rating grades wet braking traction measured under controlled conditions on specified government test surfaces of wet concrete & asphalt. There are four grades for traction: AA being the highest, down to A, B & C. All tyres must reach the level represented by a "C" rating to be sold in the U.S.A.
Test Procedure - Test tyres are mounted on wheels & inflated to 24psi (165kpa). These wheel / tyre assemblies are then fitted to the test (instrumented) trailer. Each tyre is loaded to 492kg (1,085lbs). The test trailer is towed over the wet concrete & asphalt surfaces at a speed of 65kph (40mph). Water depth is the same for each test. The trailer brakes are locked-on as the trailer reaches the wet section of the skid-pavement. The tires are dragged in this condition, the friction generated is measured. This test is done on the concrete & the asphalt surface. Twenty measurements are taken on each surface, these results are averaged to give a final result. Tyres are given a grading based on the friction they generate during the above test.
Application of Test Results - The tests for traction measure wet braking traction only, not straight ahead acceleration traction. The ratings achieved in these tests do not relate to cornering traction or peak-grip values like those achieved during non-skid braking tests. This is due to the fact that UTQG traction testing is done with no cornering forces & with the brakes on the test trailer locked-on.
Temperature - This rating grades a tyres ability to dissipate heat when tested under controlled conditions on a specified indoor laboratory test wheel. The are three grades for temperature, which is the same as for traction minus the "AA" rating.
Test Procedure - Test tyres are mounted on wheels at the maximum rated inflation pressure for that tyre. The tyre is run on the pulley wheel at the maximum rated loading. Successive thirty minute runs are made in 5mph increments, with the initial running speed being 75mph. This procedure is repeated until the tyre fails.
Application of Test Results - Speed is the only variable in this test. In actual using conditions, road camber, wheel alignment & vehicle dynamics are a few more factors that will also affect how much heat a tyre will need to dissipate. A tyre's speed rating is a much more specific way of expressing its ability to dissipate heat compared to its UTQG temperature rating.
jtan38
View user profile
Back to top Go down
Post  jtan38 on Tue Apr 27, 2010 12:18 pm
Rolling Eyes
jtan38
View user profile
Back to top Go down
Post  jtan38 on Wed Apr 28, 2010 8:45 am
jtan38
View user profile
Back to top Go down
Post  jtan38 on Thu Apr 29, 2010 8:18 am
2nd hand list update
18 inches prodrive grey gc06 5x114.3 no cap
16 inches 8holes kr210 with tyres
17 inches 10 holes rs replica with tyres
jtan38
View user profile
Back to top Go down
Post  jtan38 on Fri Apr 30, 2010 8:18 am
japan rays gtc gold 5x114.3 with tyres 17 inches
2nd hand hand 17 inches oz volcano bronze sprayed 5x114.3
jtan38
View user profile
Back to top Go down
Post  jtan38 on Sat May 01, 2010 10:26 am
happy labour day
poh heng tyres is open today labour day and sunday
amk av10 blk 4002
poh heng tyres
98368640
jtan38
View user profile
Back to top Go down
Post  jtan38 on Sun May 02, 2010 8:19 am
justin is not online today
please msg him at 98368640
jtan38
View user profile
Back to top Go down
Post  jtan38 on Sun May 02, 2010 12:27 pm
Cool
jtan38
View user profile
Back to top Go down
Post  jtan38 on Mon May 03, 2010 8:41 am
Goodyear Eagle F1 GS-D3 is a winner, featuring a striking, wild tread pattern
Goodyear's new ultra-performance tyre, the Eagle F1 GS-D3, developed in Europe and featuring a sweeping tread pattern and sophisticated sidewall design, is available in New Zealand in 33 sizes for rims from 15” to 21”.
The new tyre is engineered for sporty cars, sport trucks and a growing segment of highly modified cars "tuners."
"This new tyre looks fast even when standing still," Andrew Wellgreen, Marketing Manager, said. "It's Goodyear's most technically sophisticated ultra-high-performance radial ever."
The Eagle F1 GS-D3 features sweeping unidirectional V-TRED technology and a custom-blended triple-polymer AAtrax tread compound, delivering the highest quality of wet traction.
“For maximum force transfer between the steering wheel and dry roads,the tyre's OneTRED design provides continuous road contact across the tyre footprint”, Andrew said. “Eagle F1 GS-D3's OneTRED delivers maximised handling, acceleration and braking performance and optimum noise comfort”.
Directional V-TRED feature employs virtual rib technology, which efficiently transfers load from shoulder to centerline to shoulder for responsive handling. More than forty 13 to 15 inch long grooves sweep water diagonally outward to tyre shoulders for up to 7.9% shorter braking distances from 100 km/h, when compared to competitive tyres.
Eagle F1 GS-D3 is manufactured at Goodyear plants in the USA at Lawton, and in Germany at Fulda, Phillipsburg, Hanau and Furstenwalde. The new tyre already has received accolades as the best performance tyre in the market from automotive media in Germany and Great Britain, in leading publications such as Auto Bild, Sport Auto and Evo magazine.
For more information on Eagle F1 GS-D3 and to experience the tyre's performance go to www.eaglef1.com and try the experience.
jtan38
View user profile
Back to top Go down
Post  jtan38 on Tue May 04, 2010 8:09 am
2nd hand rims on sale
19 inches centre black side chrome rims with asy f1 5x114.3
16 inches sa67replica with black side 8 holes with RED LINING
17 inches grey replica 5x114.3 wotj tresu
jtan38
View user profile
Back to top Go down
Post  jtan38 on Tue May 04, 2010 11:42 am
Very Happy
jtan38
View user profile
Back to top Go down
Post  jtan38 on Wed May 05, 2010 8:10 am
jtan38
View user profile
Back to top Go down
Post  jtan38 on Thu May 06, 2010 8:14 am
jtan38
View user profile
Back to top Go down
Post  jtan38 on Thu May 06, 2010 11:43 am
amk ave 10 blk 4002
poh heng tyres
98368640
jtan38
View user profile
Back to top Go down
Post  jtan38 on Fri May 07, 2010 8:26 am
2nd hand list
17 inches stream rsz rims with tyres 5x114.3
19 inches staggered rims with tyres for bmw 3 series
16 inches te37 replica silver 4x100
jtan38
View user profile
Back to top Go down
Post  jtan38 on Fri May 07, 2010 12:08 pm
Very Happy
jtan38
View user profile
Back to top Go down
Post  jtan38 on Sat May 08, 2010 8:25 am
jtan38
View user profile
Back to top Go down
Post  jtan38 on Sun May 09, 2010 8:04 am
jtan38
View user profile
Back to top Go down
Post  jtan38 on Sun May 09, 2010 12:11 pm
SALE!! SALE!!!
special offer for 2nd hand rims today
15 inches 50ea 2nd hand no tyres
16 inches 60es 2nd hand no tyres
17 inches 80ea 2nd hand no tyres
all design to choose from
today only!!!!
amk ave 10 blk 4002
poh heng tyres
98368640
jtan38
View user profile
Back to top Go down
Post  jtan38 on Mon May 10, 2010 8:07 am
jtan38
View user profile
Back to top Go down
Post  jtan38 on Tue May 11, 2010 8:19 am
dunlop 703
jtan38
View user profile
Back to top Go down
Post  jtan38 on Tue May 11, 2010 11:36 am
hi
jtan38
View user profile
Back to top Go down
Post  jtan38 on Wed May 12, 2010 8:25 am
19 inches staggered m5 replica with fk452 5x120 for bmw 5 series
19 inches staggered mesh replica 5x120 for bmw 3series
17 inches black mugen replica 5x114.3 with falken
15 inches spoon rims black and white 50ea
jtan38
View user profile
Back to top Go down
Post  jtan38 on Wed May 12, 2010 11:43 am
jtan38
View user profile
Back to top Go down
Post  Sponsored content
Back to top Go down
Back to top
Permissions in this forum:
