Search
Display results as :
Rechercher Advanced Search
Latest topics
» CARBON BONNETS AND AERO PARTS FROM CARBON TEKNICS
Mon Sep 24, 2012 4:17 am by samurex31
» WTS - Ultra Gauge EM ver 1.2 (New)
Sun Sep 16, 2012 6:13 pm by Raiijin
» RainAway Nano-tech Glass Coating Treatment
Fri Dec 09, 2011 12:22 am by GT35R
» Honto Racing - A chance to win an IPAD2 when you purchase LUKAS, FINEVu or MIR Blackbox!
Wed Nov 30, 2011 3:35 pm by hontoracing
» Online dating for business women. Dating mabie.
Thu Aug 04, 2011 8:26 pm by Guest
» Dating nancy. Ovation dating guitar.
Thu Aug 04, 2011 12:09 pm by Guest
» Newbie in the forum
Wed Aug 03, 2011 8:23 pm by Guest
» Auto Tran's Problems?
Fri Jun 24, 2011 1:07 pm by win
» Name for Sg Bravo Forum
Fri Jun 24, 2011 12:55 pm by chinalim
Social bookmarking
Bookmark and share the address of Singapore Bravo Forum on your social bookmarking website
Navigation
 Portal
 Index
 Memberlist
 Profile
 FAQ
 Search
Affiliates
free forum
POH HENG TYRESNEW THREAD
Page 2 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Go down
g
Post  jtan38 on Mon Apr 28, 2008 8:31 am
SS535
Winning combination of performance and comfort. Federal's SS535 brings new meaning to high performance. Superior performance, uncommon handling, combined with exceptional acceleration and stopping capabilities in wet/dry weather and surfaces.
Features:
* Our latest tire technology, TTIC, for smoothness, speed, and safety
* M.P.O. (Magnified Performance Optimization) technology- for consistent performance throughout the tire's life
* Three Radius Tread Arc delivers even pressure across the contact area
* Flange Protector protects expensive rims from potholes and curb damage
* Steel Sidewall and Belts for optimum performance in all temperatures
* Opti-Noise Technology for a quiet, comfortable ride
jtan38
Number of posts : 148
Registration date : 2008-03-25
View user profile
Back to top Go down
g
Post  jtan38 on Tue Apr 29, 2008 8:54 am
A super sports tire with ultra high-speed capabilities (over 300 km/h) for super cars. Flagship of the ADVAN series tires. ADVAN Sport offers balance at high level, giving not only sporty performance, but also excellent characteristics on wet pavement, a good ride, low noise, and so on. Ideal for performance cars, from high-powered saloons to tuned cars.
A high-grip compound created through joint development with super sports cars.
The new compound developed for ADVAN Sport was tested many times under hypervelocity conditions, and is the ultimate model by Yokohama. This high-grip rubber ensures both pliability and strength.
The state-of-the-art technology that was used to cause the chemical reaction between polymer and silica is what derived such a high performance.
A compound is usually made by compounding polymer and silica. However, Yokohama Rubber succeeded in creating a compound of higher performance by bringing about a "chemical reaction" when compounding polymer and silica.
High heat resistance and a strong grip. A type of rubber with less temperature dependency was newly developed.
Tread temperature heightens during high-load, high-velocity cruising. If the temperature level reaches an extreme limit, the tire may destabilize due to the heat, causing deterioration in the tire's grip. Thus, Yokohama Rubber, with its original technology, developed a compound that makes "the grip less susceptible to heat."
Asymmetry pattern
A highly rigid rib design is adopted for the outer side, while ribs and blocks are aligned to optimally focus on handling, braking distance and noise reduction.
Variable round grooves
These are original grooves that were cut in a round shape with different widths and angles. They prevent one-sided abrasion and ensure high performance on wet surfaces.
Grooves within grooves
"Grooves within grooves" are finely cut in the wall of the four main grooves. They improve handling performance and abrasion resistance.
Optimal design of groove ends
By controlling groove ends, handling performance, abrasion resistance and noise reduction are all kept in good balance.
Dimples and sipes
Optimal alignment of dimples and sipes ensures a stronger heat liberation effect and higher performance on wet surfaces.
Round profile durable for high-speed driving
After analyzing the state of energy used during high-speed drives, a tire form that exhibits smaller loss was newly developed. It transmits power to the road surface most efficiently.
Jointless triple-edge cover
Adopting a seamless belt cover improved the rigidity of the tire. It provides secure handling even during high-speed cruising.
Overlap jointless winding system
Durability was improved by overlapping the cover edge. This construction achieves high stability in hypervelocity driving.
Rayon carcass material
Rayon has low dependency on temperature and it hardly alters the characteristic of the carcass. Thus, driving comfort is improved by using rayon for the carcass.
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Wed Apr 30, 2008 8:45 am
[quote author=fmx board=forsale thread=3623 post=114884 time=1205481674]hi justin, i'm another satisfied customer of Poh Heng.
good prices, efficient service and a nice surprise that we were all under bravo company during bmt 8-)
found absolutely no reason not to make repeat purchase from you in the future.
thanks dude
*black cerato tht changed wheels this afternoon*[/quote]
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Thu May 01, 2008 9:32 am
Dynamic ¡°V¡±-shape aqua pattern design.
The drainage performance has been maximized and driving comfortableness has been strengthened.
In addition, the riding comfort is improved by reducing the noise and vibration with a new dynamic pattern and sidewall design contributes not only the performance but also styling in highest efficiency.
The improvement of driving comfortableness.
The wider tread block in the center of tire makes handling and driving comfortableness satisfied and also, improves the comfortableness remarkably at high speed and increases impact absorption during driving at the rough road.
The highest turning ability at high speed.
The wider block design at shoulder part increases the strength of block and is superior to turning ability and elusion of unpredictable situation by raising the resistance to crosswise
Force.
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Fri May 02, 2008 8:25 am
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Sat May 03, 2008 8:38 am
SPORT RIMS
What it's supposed to do:
Improve handling by reducing upsprung weight and allowing the fitment of wider tyres. It's safe to say that the majority of alloy rims are brought for their style rather than their function. Still, there are many benefits in putting on a set of lightweight wheels/rims to replace the steel or alloy ones that came with the car. Forged rims are extremely light and they allow the car suspension to do its work more effectively, thus improving both steering response n ride comfort. With Technological advances, low profile tyres are becoming less unforgiving in their ride characteristics and they are alos quite cheap these days, so a plus-one upgrade from standard set-up gives noticeable handling improvements with hardly any impact on the comfort.
The 2005 Wheels Tyre Test is published in the May 2005 edition of Wheels magazine, in newsagents now.
the tyres were tested for
Stopping distance - wet and dry
Cornering - wet and dry
Slalom - dry
Stopping Distance - WET
1. Maxxis Victra MA-21
2. Michelin Pilot Preceda
3. Goodyear Eagle Revspec RS-02
4. Toyo Proxes T1R
5. Kumho Ecsta KU19
6. Bridgestone Potenza S-03
7. Dunlop Direzza DZ101
8. Yokohama AVS Sport V102A
9. BF Goodrich G-Force Sport
Stopping Distance - DRY
1. Goodyear Eagle Revspec RS-02
3. Toyo Proxes T1R
4. Maxxis Victra MA-21
5. Bridgestone Potenza S-03
6. BF Goodrich G-Force Sport
7. Yokohama AVS Sport V102A
8. Kumho Ecsta KU19
9. Dunlop Direzza DZ101
Cornering -WET
2. Toyo Proxes T1R
3. Maxxis Victra MA-21
4. Bridgestone Potenza S-03
5. Kumho Ecsta KU19
6. Michelin Pilot Preceda
8. Dunlop Direzza DZ101
Cornering - DRY
1. Bridgestone Potenza S-03
2. Goodyear Eagle Revspec RS-02
3. Michelin Pilot Preceda
5. Yokohama AVS Sport V102A
6. Dunlop Direzza DZ101
7. BF Goodrich G-Force Sport
8. Toyo Proxes T1R
9. Kumho Ecsta KU19
Slalom - dry
3. Yokohama AVS Sport V102A
4. Goodyear Eagle Revspec RS-02
5. BF Goodrich G-Force Sport
6. Maxxis Victra MA-21
8. Toyo Proxes T1R
9. Kumho Ecsta KU19
Noise
3. BF Goodrich G-Force Sport
4. Yokohama AVS Sport V102A
5. Goodyear Eagle Revspec RS-02
8. Toyo Proxes T1R
9. Kumho Ecsta KU19
Price
1. Maxxis Victra MA-21 - $198
2. BF Goodrich G-Force Sport - $201
3. Kumho Ecsta KU19 - $235
4. Dunlop Direzza DZ101 - $288
5. Michelin Pilot Preceda - $290
6. Goodyear Eagle Revspec RS-02 - $298
7. Toyo Proxes T1R - $312
8. Bridgestone Potenza S-03 - $355
9. Yokohama AVS Sprt V102A - $359
the OVERALL results (Noise and Price don't count) in the 235/45/R17 size were:
5. Toyo Proxes T1R
6. Yokohama AVS Sprt V102A
9. Kumho Ecsta KU19
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Sun May 04, 2008 8:29 am
amk ave 10 blk 4002
poh heng tyres
98368640
justin is not online today
please msg him
jtan38
View user profile
Back to top Go down
h
Post  jtan38 on Mon May 05, 2008 8:23 am
Great selling ultra high performance tire. It is rewarded Taiwan Excellence 2006 and ranked 3rd popular tire to Japanese drifting enthusiasts.
Description :
30/35/40/45/50/55/60 Series
“H”, “V”, “Z” Rated
Federal's greatly successful UHP tire-ss595 has been repositioned and renamed as the 595. ss595 is rewarded Taiwan Excellence and has great sales in the world. 595 has been made slight technical changes in order to suit the purpose and take the abuse of drifting competition. In Japan market, 595 is known among drifting field and has been ranked the 3rd popular tire to Japanese drifting enthusiasts. 595’s excellent grip can satisfy those requiring both flat-out performance and the basic comforts of everyday driving. Aggressive V-shaped tread and innovative silica compound enhance the level of adhesion, resistance to aquaplaning to maximum, gives your car ultimate control in acceleration, cornering and braking.
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Tue May 06, 2008 8:42 am
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Wed May 07, 2008 8:33 am
polarshift wrote:POH HENG and Ang Mo Kio Ave 10, Blk 4001. I traded in the dunlop sp31 that comes with my new FIT today. Intended to change Bridgestone GR80 but no stock, but PH Justin quoted the cheapest (after trade) among few shops I called.
I replaced it with Falken ze326.
Good service, fast, friendly pple (and Justin mum will always ask you to drink water). Same good service I have had since first visit the shop 2 years ago.
jtan38
View user profile
Back to top Go down
F
Post  jtan38 on Thu May 08, 2008 8:42 am
Falken Tire Announces New Azenis RT-615
Falken Tire Corp. is proud to début the next generation of RT (race tuned) Spec Sport Radials for North America and the world. Derived from a motorsport lineage that begins with Nürburgring's Nordschleife, the Super Taikyu Endurance Race Series, and world-class circuits around the globe; the World Spec Azenis RT-615 is poised to initiate the battle for Pure Sports domination.
�The development of the RT-615 was spawned from the ever growing need for true motorsport level products without the inherent drawbacks of track dedicated R-Compound tires. As the OEM's continue to focus more on attitudinal tire characteristics such as NVH (noise, vibration, harshness), the availability of unorthodox sports radials has become all but non-existent. Generally speaking, premium sports customers have been forced to choose between watered down versions of flagship summer tires and limited life cycle R-compound rubber. The World Spec Azenis RT-615 signals the rebirth of truly premium Pure Sports products for discriminating sports drivers.�
The World Spec Azenis RT-615 incorporates the absolute latest in design philosophy and materials. �Every aspect of this project has focused on a single development objective. To create and launch a new genre of sports radials that have the credentials to attack authentic JDM brands like Yokohama Advan and Bridgestone Potenza. While we know these competitors may ultimately modify their specifications to meet US glass transition point compound standards, we are prepared to go head to head against the best in the world�
jtan38
View user profile
Back to top Go down
F
Post  jtan38 on Fri May 09, 2008 8:37 am
Falken Ziex XE-912
ZIEX ZE912
Hybrid-Asymmetric Pattern Design - Provides authentic High-Performance grip and genuine touring confidence. Optimized inner and outer tread patterns ensure that dry performance, stability, and all-season grip are available when you need it. Infinite Sype Sequence - Full depth sypes greatly improve winter traction though-out the life of the tire. R.W.I. (Rotation Wear Indicators) - Tell you when you rotate your tires. Quad High-Volume Circumferential Groves - Delivers increased hydroplane resistance for maximum wet stability. High Angle Variable Cross Grooves - Increases tread stability while effectively evacuating water away from the contact area.
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Sat May 10, 2008 8:35 am
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Sun May 11, 2008 8:30 am
RE001 Adrenalin is an ultra high performance tyre. It not only provides excellent grip and performance in all situations but also high level of comfort not expected from a sporty tyre.
RE001 Adrenalin is a sports tyre crafted to deliver extreme driving pleasure. With advanced technology RE001 Adrenalin creates an enhanced driving experience. A 3D centre block, reinforced sidewall, large footprint and rigid base compound combine to increase on road tyre stability and allow quick, smooth cornering. Its asymmetrical rigid tread design gives the driver direct steering response and more control when cornering, while at the same time improving noise levels and comfort, even when worn.
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Mon May 12, 2008 8:33 am
ST08 left, S-Drive right.
Similar threads, except S Drive has 3 grooves lesser.. shoulder and center.
amk ave 10 blk 4002
poh heng tyres
98368640
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Tue May 13, 2008 8:40 am
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Wed May 14, 2008 8:45 am
How tyre treads help improve your driving experience
Many people choose their tyres by looking at the tread pattern. Some may pick a tyre by how "cool" the pattern looks, and they may end up with tyres that emit a lot of noise while driving. Or they may discover that the tyres do not offer good grip and road handling, thereby compromising on personal safety.
What exactly can you tell about a tyre from those grooves, valleys and patterns? And is there a tyre tread that works best for you?
Here are some quick tips to help you make sense of tread patterns:
The Rubber Blocks: otherwise called tread blocks, they are the ones that come into contact with the ground and thus determine how well the tyre grips the road. The more tread blocks there are, the better the grip.
The Valleys & Grooves: when it rains, these little grooves are hard at work! Water on the tyre is channeled into them where they are stored. As the tyre roll, the water is then released from the back. If there are not enough grooves, water cannot be dispersed from the surface of the tyre which can cause the tyre to loose contact with the road, commonly called Aquaplaning.
So in short, the blocks provide better grip in dry conditions while the grooves and valleys helps disperse water allowing for better control and handling in wet conditions. To ensure that the tyre offers a safe ride, there needs to be a balance between the blocks and the grooves and this relates to today's topic - tread patterns. These come in 3 generic patterns; symmetrical, directional and the latest - asymmetrical.
Symmetrical tyre treads looks the same from all angles and can be fitted onto either side of the car
Directional tread patterns point in a certain direction and have to be fitted in a specific direction
Asymmetrical tyre treads have distinct patterns on the outside zone of the tyre that is unique and different from the pattern on the inner zone.
Asymmetrical tyres provide a good compromise to the grip and wet paradox:
Outer zone: bigger & firmer blocks for the outer shoulders to ensure cornering stability
Center & Inner zone: more grooves for better water drainage to ensure better performance in wet conditions
Michelin, the world's leading innovator in tyre technology, modeled its new generation Pilot series tyres (Pilot Sport and Pilot Preceda) on a four-grooved asymmetrical tread pattern with different rubber compounds used for the inside and outside of the tyre. The result is a tyre that is perfectly suited for the tropical climates of Asian countries as it is designed for superior road grip and steering precision in both wet and dry conditions
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Thu May 15, 2008 8:44 am
BENEFITS
High adherence sports tread compound
Delivers exceptional grip for superb road handling and progressivity
Braking and acceleration in wet and dry conditions
Special sidewall rim protectors give the tyre its sporty look plus deflect road hazards
Ultra quiet ride
Summary
A TRUE SPORTS TYRE FOR ASIA... Designed for Asian consumers with superior control in all road conditions; unparalleled wet handling capabilities for heavy monsoon weather conditions and the most 'silent' tyre in its class.
The new Michelin Pilot Preceda is for motorists who have a passion for on-road performance without compromising silence and comfort, in addition delivering higher precision cornering, exceptional responsiveness and more stability to match the road action. These attributes are requirements of modern drivers who demand peak handling yet still value a smooth ride.
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Fri May 16, 2008 8:42 am
[QUOTE=iliewminator;23222]Justin,
The Goodyear Eagle LS2000 Hybrid II are very comfy and quiet tires .. . good stuff . .. Thanks . .. Very Happy[/QUOTE]
jtan38
View user profile
Back to top Go down
Re: POH HENG TYRESNEW THREAD
Post  alex on Fri May 16, 2008 9:35 am
got ready stock for federal ss595? i'm looking for 225/45/r17
alex
Webmaster
Webmaster
Number of posts : 33
Registration date : 2008-03-23
Character sheet
woo:
0/0  (0/0)
View user profile http://fiatbravo.clubdiscussion.net
Back to top Go down
g
Post  jtan38 on Sat May 17, 2008 8:39 am
jtan38
View user profile
Back to top Go down
g
Post  jtan38 on Sat May 17, 2008 11:29 pm
sorry folks
didnt work today cause my lst born has just arrived...hee
yeah baby boy.....
cheers to all the fathers out ther
jtan38
View user profile
Back to top Go down
Post  jtan38 on Mon May 19, 2008 10:50 am
hey...justin's not online today coz picking up new born
if anything, msg him at 9836 8640
thanks!!
jtan38
View user profile
Back to top Go down
fg
Post  jtan38 on Tue May 20, 2008 8:29 am
What is the only link between the vehicle and the road?
The contact patch of a car tyre is roughly the same size as the palm of your hand. A tyre has to withstand and transmit great forces. This is why not only the tyre itself is important, but also the fitting and maintenance.
jtan38
View user profile
Back to top Go down
f
Post  jtan38 on Wed May 21, 2008 8:40 am
Congratulations Justin.
Hope your New Born is healthy and will grow to be a good strong man like yourself.
Cheers and god bless !
jtan38
View user profile
Back to top Go down
Post  Sponsored content
Back to top Go down
Back to top
Permissions in this forum:
